1920's shower mixer - American Standard Re Nu ? B201 or B202
Discussion in 'Shower & Bathtub Forum & Blog' started by dradprice3, Oct 15, 2011.
  1. dersh16
    dersh16 New Member
    Feb 15, 2013
    New Jersey
    Ihave this same mixer and need washers for replacement. Also when it goes back how are the plungers to be positioned when the spindles is put back in. Any help Thanks, Jack
  2. 336flyerfan
    336flyerfan New Member
    Aug 28, 2012
    Dearborn, Mi
    Plungers should be pushed in all the way and then turn the handle clockwise. The stem is a double threaded stem so if it doesn't shut off correctly the first time, turn the handle 180 degrees and try again. You can get the washers frome Lowes...you'll need to buy the Danco faucet repair kit. You'll find the washer you need along with a bunch of other stuff you'll never use but it's only $4.
  3. dersh16
    dersh16 New Member
    Feb 15, 2013
    New Jersey
    Thanks for the great info. One other thing if you don't mind. The plunger on the right side I can push in but can't get it out to change the washer. Other than prying it out with say a straight claw hammer, any tip?? Thanks, Jack
  4. 336flyerfan
    Aug 28, 2012
    Dearborn, Mi
    Don't pry anything...the plungers aren't available at this point anymore and are made of bronze. I am in the midst of having plungers reproduced from a set of originals to help solve the majority of issues people are experiencing with this valve. Meanwhile, try Blaster from home depot. You could also sparingly try vinegar...just don't leave it on much longer than 10 minutes and flush with water. You're going to need patience regardless.
  5. dersh16
    dersh16 New Member
    Feb 15, 2013
    New Jersey
    I got it out with some heat. I put an acetylene torch on it for a bit and it loosened up. I made the washers with what I could put together from a local hardware and it is up and running with no leaks. Thanks for everyone's help and suggestions Jack
  6. Jim Fleming
    Jim Fleming New Member
    Sep 15, 2013
    Pennsylvania
    B201 202
    Could I please get that diagram/parts list?
    jfdogman@aol.com
  7. Friend Dean
    Friend Dean In the Trades
    Jan 2, 2014
    Master Plumber and House Surgeon
    Baton Rouge, Louisiana
    I am in the process of making one of these Standard Shower Valves operational again - DSC07230.jpg
  8. Friend Dean
    Jan 2, 2014
    The Question I have is: There is a Thumb Screw on the Lid, that when removed, allows access to the Little Screw on the Hot Shuttle/Plunger - what does that Little Screw do? Adjustment for travel of Hot Shuttle? Like a Stop Screw?
  9. Smooky
    Smooky Well-Known Member
    Apr 4, 2011
    North Carolina
  10. Friend Dean
    Jan 2, 2014
    Thank You - I actually downloaded this yesterday in the process of finding this forum.
  11. 336flyerfan
    Aug 28, 2012
    Dearborn, Mi
    Standard Valve B201
    Great news for everyone who loves this old valve - Barry Walters now has the plungers for both the hot and cold side available. They work really well but you may need to shim your washers so it shuts off completely due to the wear pattern on your stem. These parts haven't been available in several decades!!!!
  12. 336flyerfan
    Aug 28, 2012
    Dearborn, Mi
    The little screw on the hot plunger is an early version of a scald protector.
  13. InSearchofAmStdPlunger
    InSearchofAmStdPlunger New Member
    Apr 1, 2014
    IN
    This is great news that this plungers are now available since I've been waiting 10 years to get a hot and a cold one. I search the Barry Walters site and didn't find any. Can you send me to the link so I can order these? Thanks ahead of time for the heads up!
  14. 336flyerfan
    Aug 28, 2012
    Dearborn, Mi
    Goto www.barrywalter.com you'll need to talk with Barry Sr directly at 970 867-3858. The plungers are not listed in his catalog. This company is a first class operation and Barry is a really busy guy (might need to leave a few messages).
  15. 10_local55_500
    10_local55_500 New Member
    Apr 17, 2016
    any way I could get that drawing?\
    pjmaforce@gmail.com
Similar Threads: 1920's shower
Shower & Bathtub Forum & Blog Lustrolite shower wall covering Yesterday at 11:17 AM
Shower & Bathtub Forum & Blog Delta rain can shower head install Sunday at 7:12 AM
Shower & Bathtub Forum & Blog Cutting into block wall for shower water supply Feb 14, 2017
Shower & Bathtub Forum & Blog Concrete shower pan; do I need a liner? Feb 14, 2017
Shower & Bathtub Forum & Blog Shower Leak to basement... Feb 10, 2017
