11" rough in??? Do I get 10" toilet or is there another option
Discussion in 'Toilet Forum discussions' started by PabNYC, Dec 11, 2004.
  1. PabNYC
    PabNYC New Member
    Dec 5, 2004
    NYC
    I just bought a new house and the rough in is 11". The existing 30 y.o. toilet fits perfectly but I have never heard of an 11" rough in. Should I just get a 10" toilet and deal with the space behind it or is there another option? I went to my local plumbing supply and they told me to have a plumber get an offset flange.
    Pablo
  2. Terry
    Aug 17, 2004
    You are close on this.
    Most 12" rough toilets have 3/4" behind the toilet, thus they will mount with 11.25" from the wall, measured from the wall to the center of the drain.
    Sometimes you can move the bolts out that extra 1/4" and install the standard 12" toilet anyway.
    If not, the other option is the 10" toilet.
    TOTO now has a 10" dual flush at the factory.
    I'm bringing some here for the Seattle area.
    CST412MF.10
    [​IMG]
  4. PabNYC
    PabNYC New Member
    Dec 5, 2004
    NYC
    Thanks
    Thanks Terry!!!
    I have a 12" toilet to replace also so I will buy that one first and try it to see if it works.
  5. Fit
    Fit New Member
    Apr 7, 2008
    Minnesota
    Bump!
    Hi all-
    I'm definitely not the plumbing type but ran across this thread and am wondering if things have changed in the last few years.
    I'm remodeling the downstairs bath... 11" rough in exactly, in concrete. I cannot adjust the screws forward at all. The old toilet was smack right against the wall.
    I was coveting the various ECO Toto's based on the reviews here but all seem to be 12" roughs.So I guess 10" is it? Or does the adapter allow me to readily sit a 12" rough on an 11" rough?
    I was going to do this myself but may need to go the plumber route to get this right.
  6. Reader Review
    Reader Review Comments by readers
    Jan 2, 2006
    The Eco Drake works at 10-7/8"
    So 11-0" shouldn't be a problem.
  7. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    The Drake and Eco-Drake both show in their specs a 1 1/8" gap behind the tank. In theory it should fit an 11" rough in with a 1/8" gap betwen the wall and the tank. However, There are tolerances in the manufacturing process and we are hoping that it would not be a plus sized toilet. You could give it a try and see if you get it in there... Its a shoehorn fit for sure!
    [​IMG]
  8. Fit
    Fit New Member
    Apr 7, 2008
    Minnesota
  9. Fit
    Fit New Member
    Apr 7, 2008
    Minnesota
    Really? Hmmm.
  10. Terry
    Aug 17, 2004
    We set the Toto Drake at 11" all the time.
  11. Fit
    Fit New Member
    Apr 7, 2008
    Minnesota
    Thanks Terry.
    And thanks for the service this forum provides.
  12. msimon
    msimon New Member
    Apr 2, 2008
    Los Angeles, CA
    We had the same problem last summer (2007) with a 11" rough-in.
    HD sells a (Glacier Bay) Niagara 1.6 gpf toilet with the 11" rough-in. Note this is the 1.6 gpf version (not 1.3 gpf). We've had no problems flushing larger "objects".
    The Niagara toilets are flapperless. I like this, since it seems to me that I'm replacing flappers every two years or so, even w/out the use of cleaning tablets in there. Also, there's no wasted water running down the drain while you wait for the float to fall back down. Out of interest, does anyone else perceive this as a better design to toilets with the flappers?
  13. msimon
    msimon New Member
    Apr 2, 2008
    Los Angeles, CA
    HDis the big box outlet with the initials H.D.
  14. Terry
    Aug 17, 2004
    Not when we have reports of the tray sticking against the side of the tank and running.
    Or how often the handles break.
    It certainly is an option though. They work from 10" to 12"
  15. msimon
    msimon New Member
    Apr 2, 2008
    Los Angeles, CA
    Hmm, it still seems like a good design to me. It's the execution that seems flawed.
    That's the manufacturer using a cheap quality part.
    This I have seen when my 4-year old (or myself) gives the handle a half-harded push and only half the water empties out of the tray. A simple fix is to push a little harder and pull up on the handle afterwards. The whole step takes less than a second. I list this one in the same category as slapping the handle on a regular toilet and having the chain kink, which also causes the water to continuously run.
  16. Terry
    Aug 17, 2004
    Except there are lots of people with hearing problems, and some with faked hearing problems.
    They hear the water running and running, but just walk out.
    Some of my older customers can't hear when they have a leaking toilet.
    They give me this funny look when I ask them how high their water bill is sometimes.
    And when they look at their next water bill, Well then it's imperative that I get right out there and fix their old leaker.
    You don't have to jiggle the Toto handle.
  17. Redwood
    Dec 15, 2007
    Service Plumber
    I still remember well the first Niagra Flapperless Toilet I ever saw. It was in the home of an HD employee and it was clogged! They were paying me to auger the toilet...
    I told him that he should stop buying toilets there because they don't sell the Toto line.:D
    I'm less than impressed with the Niagra Flapperless design and have now augered quite a few of them. I do wonder though... When Niagra goes belly up where are the parts going to be?:confused:
  18. djh1973
    djh1973 New Member
    Apr 13, 2008
    Tour Manager/Handyman
    Chicago
    Can't an offset closet collar (flange) be used if you are able to remove the old one?
  19. taysan
    taysan Member
    Apr 12, 2008
    Toronto, ON Canada
    I was considering using an offset flange to move my toilet over a couple of inches - purely cosmetic reasons. However, I found that the offset flanges I could find (and it of course makes sense) are quite a bit deeper than a standard flange, meaning you need to lower the drain in the floor, which then of course impacts your slope to the stack.
    Maybe there are offset flanges out there that you can retrofit into an existing system, but it seems to me the very nature of an offset flange would require some additional height.
    While I'm typing, I have a silly question. It seems 'rough-in' for toilets actually means from the center of the drain to the drywall, not the framing of the wall. When I read 'rough' I have always assumed it meant to the framing, i.e. the rough carpentry. Thankfully I've not been installing toilets all over the place ;)
    So is this really the definition of 'rough-in' - i.e. to the finished wall surface?
  20. jadnashua
    Yes, the rough-in on a toilet flange is from its center to the FINSHED wall (note, this does not need to deal with baseboard unless it is huge, but wainscoating can be a problem - it is the new thicker wall!). that may be one reason my most toilets have a planned gap behind them, but it varies...if you install the flange properly, any 12" toilet should fit on a 12" rough-in.
  21. LG Jon
    LG Jon New Member
    Nov 15, 2010
    Calif
    I also have an 11" rough in, and would like to use the Drake. But I notice the current model shows only 13/16" behind the tank (as opposed to the 1 1/8" shown in the drawing above).
    http://admin.totousa.com/Product Downloads/SS-00239, CST454CEF_G, V.08.pdf
    Will that still work with 11"? Sounds tight...
    If not, is there another 11" option? I'd rather not go to 10" and have that space behind :-(
Similar Threads: rough toilet
Toilet Forum discussions What is the rough in distance for this toilet? Jan 9, 2017
Toilet Forum discussions Best American Standard 12" Toilet for 11" Rough In Jan 2, 2017
Toilet Forum discussions found a leak through a hole in the toilet waste pipe Jun 25, 2016
Toilet Forum discussions Any round-bowl Toto toilets w/14" Unifit rough-in? Jun 9, 2016
Toilet Forum discussions Replacing a 1929 14" rough toilet Apr 13, 2016
