View Full Version : Shower & bathtub Forum
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23
  1. Reglazing?
  2. shower stall leak
  3. Fiberglass shower drain in concrete floor
  4. wall mount not sticking
  5. Where can I buy a 4 port diverter for a Peerless Marielle?
  6. New Shower Install
  7. Dripping new Delta Faucet
  8. Let me try again....how can I plumb a hand held shower and overhead??
  9. dripping single handle shower faucet
  10. to install or not to install
  11. Replacing old shower valve
  12. Bathtub Faucet Maintenance
  13. Upgrading a Shower Stall
  14. Custom Fiberglass Shower Pan?
  15. Loss of Water Pressure in New Shower Install
  16. Nonstandard Tub Strainer ... . . . . grrrr!
  17. Diverter Valve failure - need indentity
  18. Shower Stall Leak
  19. Old Crane bathtub stopper - HOW to remove it?
  20. NO water comming out of shower
  21. New Handles & Spout
  22. American Standard Push/Pull Conversion Kit
  23. Leaking shower receptor
  24. abs or pvc shower drain? which is better?
  25. steel tub installation
  26. slow bathtub drain
  27. 5 port diverter?
  28. steam generator drain
  29. 3-hole shower faucet repl
  30. Fastening shower neo angle shower doors to fiberglass
  31. loose tub spout
  32. Leaky tub spout.
  33. No Room for 2nd floor bathtup trap
  34. Install shower arm
  35. Changing tub/shower fixtures
  36. Backerboard for shower/tub
  37. Kohler faucets - replace or upgrade
  38. help with tub backboard for tileing
  39. New Shower Faucet Question
  40. Adding shower to old tub
  41. pressure balance valve
  42. Hot/Cold Reversed & Metal Sliver in Delta faucet
  43. symonns diverter problems
  44. Tub Drain Replacement
  45. Shower low hot water pressure
  46. bathtub drain
  47. shower drain won't fit undersized 2" pipe
  48. Need advice on installing a bathtub on uneven floor
  49. Where to put the AAV
  50. Caulk Shower Receptor
  51. multiple body sprays
  52. Valve Seat Problem
  53. bath faucet leak, diverter problem
  54. I need advice on my bathtub
  55. leak behind shower wall
  56. Tighten tub spout
  57. Grohe Volume Controls Recessed Too Far
  58. Leaky bathroom tub faucet
  59. Old Valve Body New Valve Stems
  60. Shower plumbing driving me crazy!
  61. Symmons Temptrol Seat Replacement
  62. Moen Shower Handle Hub Removal
  63. Danze vs. Delta vs. Moen
  64. bath drain removal
  65. Non standard size shower receptor.
  66. curbless shower
  67. Outside Wall Plumbing
  68. Help Moving a shower drain under floor
  69. SLOOOOOOW Bathtub drain
  70. New Tub Drain Won't Shut Off
  71. Defective Steel Tubs
  72. sewer odor
  73. Leaking tub faucet
  74. Refinish or replace cast iron tub?
  75. Shower pan installation
  76. Installing cast iron tub
  77. help trap setting
  78. Dripping Shower Head
  79. shower diverter
  80. Volume control in line between PB valve and shower head
  81. broken screw
  82. add a shower head?
  83. Price Pfister Shower Diverter Removel
  84. Where is this leaking coming from =(
  85. Bathtub hot water faucet handle screw is rusted
  86. Large diameter shower arm flange/escutcheon
  87. Trimming out a fiberglass combo shwr/tub
  88. New Tub Filler
  89. can i tile over tile in a stand up shower
  90. shower leak
  91. Leaking Grohe model 34-436.
  92. Bath fan exhaust venting
  93. replaced cartridge, still leaks!
  94. plumb tub/shower with cpvc in bath remodel
  95. Bathtub faucet hard to turn off
  96. Is access necessary behind tub fixtures?
  97. "Tuscany Brass" bath / shower faucet parts?
  98. Frozen screws in shower strainer
  99. Acrylic or fiberglass?
  100. crappy house
  101. Diverter lever not working?
  102. Help for Pop-Up Drain for Jacuzzi
  103. Faucet change
  104. Converting a tub/shower to shower only
  105. Knocking Hot Water Pipes
  106. cold water faucet leaking...brrrrr
  107. Intermittent Hot Water Problem
  108. Tub Faucet Hot/Cold Handles Don't Stop
  109. Shower diverter knob not working
  110. Shower 2.5 Gal Restrictions
  111. Tub to shower conversion
  112. How do I seal a leaking shower drain?
  113. Drain help for new acrylic shower install
  114. Can a shower door open into the shower?
  115. drilling faucet holes in..
  116. how to 'ground' a gelcoat tub's flimsy quality? also, vikrell question.
  117. hot water problem
  118. where is the water supply control for our tub in the bathroom?
  119. Help! Faucet won't align straight
  120. Bad tub/shower valve?
  121. Shower/tub dumping water help before house becomes Atlantis
  122. Tub overflow leak into bathtub
  123. Diverter Valve troubles
  124. Very little hot water in shower - 50 gal tank not issue - Please Help!
  125. Tub Overflow leaks to downstairs
  126. Shower Stall Leaking
  127. Intermittent Hot Water
  128. Incosistent hot water
  129. house plubming lieakage in third floor bathroom
  130. Tub to Shower conversion to save space
  131. Broken pipe on tub spout
  132. I failed my 'pre-glue' inspection...
  133. Leaking Price Pfister Handles
  134. Tub Drain
  135. Grohe Atrio shower faucet install
  136. Brass Shower Drain
  137. High Pitched Whistle In the Shower
  138. 1 diverter or 2?
  139. old "Valley" shower
  140. Oatey Shower Drain Install
  141. Leaking Shower Head
  142. purchase drain and overflow
  143. venting my new attic bath
  144. How to fill a gap?
  145. How do I fix a leaky faucet?
  146. old tub & shower door
  147. no bathtub hot water pressure
  148. Adapting existing tub for elderly
  149. shower diverter & spout problem
  150. Cold Water in Bathtub
  151. Sower drain in concrete
  152. remove tub drain for crane bath tub
  153. Searching for freestanding shower stall
  154. Shower tub install in basement
  155. Bathtub Reglazing - anyone have it done?
  156. Setting an acrylic tub
  157. Whirlpool/shower combination
  158. Grohe bath faucet rough in
  159. Acrylic whirlpool tub refinishing?
  160. Porcher diverter - faucet still runs
  161. black specks in water--HELP!!!
  162. How hard is this? tub filler on the side, handles on one end
  163. Leaky shower?
  164. Low Water Pressure in Shower/Tub - HELP!
  165. Installling shower base--frustrations!
  166. Moen Posi-Temp vibration
  167. Moen Dialcet shower faucet leak
  168. diverter question
  169. tankless water heaters
  170. cold water leak
  171. Glass coating for shower doors
  172. Help drilling two holes in my cast iron tub.
  173. Neo-Angle Shower: Caulk Inside or Not???
  174. 3 port diverter for sale
  175. Push-button diverter
  176. Clogged Bathtub -- Difficulty With Shaft in Overflow Tube
  177. Need Help finding trim kit for Hessco Passport Ensemble whirlpool!
  178. NYC reglazing companies > tubs > tiles > sinks
  179. Basement bathtub/ pump options?
  180. looking for a special bathtub trap
  181. cast iiron tub - refinishing exterior - suggestions?
  182. Shower Tub Valve with Integrated Shutoff???
  183. Americast bathtub vs Maax acrylic bathtub
  184. Trying To Identify the Manufacturer of a Piece
  185. what size water line for 2 shower and 1 tub (long)
  186. Tub Drain Stopper Replacement
  187. Tub filler nipple
  188. price pfister dripping shower head
  189. help on tub
  190. Bath tub drain slow - How does water flow uphill
  191. Installing a fiberglass tub
  192. Shower stall problem
  193. rough-in for body sprays
  194. Leaky Valley Shower
  195. Found source for Crane obsolete Drexel style faucet handles
  196. Remodeled Bathroom Venting
  197. Pressure Balance vs. Thermostatic Valves
  198. soaking tub/shower module
  199. New Tub Drain
  200. Tub/Shower Combo Drain
  201. "Rain-can" showerheads & such
  202. clawtubs for sale completely refinished
  203. using unions in shower valve plumbing, yes or no?
  204. square trim shower drain
  205. 60" TUB IN A 60 1/2" SPACE
  206. low hot water in the bath tubs?
  207. stan-sure quality
  208. silicone remover by AMTEX??
  209. Doorless walk-in shower
  210. Cement board under shower and tub?
  211. Handle Puller problem
  212. Flexible copper in wall?
  213. Super Shower System?
  214. Rim mount faucet on tub
  215. new tub p-trap, drain, vent size
  216. Shower valve assembly - up vs. down
  217. Moen Dialcet shower knob
  218. How to rough in tub filler?
  219. Installing a New Spa! Help!
  220. Solo-Touch whirlpool control
  221. passport ensemble jacuzzi tub
  222. SYMMONS Temptrol MODEL A shower valve
  223. spartan shower hardware
  224. Dealing with flange on fiberglass shower
  225. no hot water from tub/shower valve
  226. shower spout adapter
  227. Where Backerboard meets tub
  228. Shower handle repair
  229. Drain shoe size
  230. removing Grohe cartridge
  231. Delta Shower Head restricter
  232. Helping the plumber
  233. jetted tub-no vacuum to pump-help
  234. shower question for hj [or anyone else]
  235. shower question for hj--or anyone
  236. Installing extra layer of plywood
  237. HELP!! Wet stains on ceiling under shower tub
  238. Fiberglass Shower Pan
  239. Swanstone installation questions.
  240. MORE HELP!!cracks in fiber-glass shower walls..
  241. Bathtub trip lever issues!
  242. Bathtub/Shower Leak
  243. Are all shower faucets heat regulated?
  244. Can I reuse my tub filler?
  245. fiberglass tub vs steel
  246. 54x34 Shower Pan???
  247. Cannot unsweat brass/copper fitting
  248. Converting old 2-faucet to single faucet on tub/shower
  249. Need help with my tub drain
  250. Side drain tub
