andrewge
San Jose, California
Hi,
My busted old Honeywell gas control valve has been discontinued years ago.
Bradford White provided the part number that led to the Resideo WT8860A1000 https://jacksonsystems.com/product/...e-ultra-low-nox-water-heaters-w-2-insulation/ as the replacement.
The attached picture shows old Honeywell and new WT8860A1000 control logic boards side-by-side.
The 2 vertical connectors on the right sides of the boards for wires from the thermopile are the only commonality between them.
On the left/old Honeywell, the
o 2 rightmost pins connect to 2 wires for a Resistance Temperature Detector (RTD) screwed on the door of burner's chamber.
o nwzr 3 pins connect to the solenoid hardware (with the protruding water temperature sensor on the back of the valve).
On the right/new WT8860A1000, the
o North/top edge connector is for the solenoid hardware.
o molex with 6 pins and the 3 on-board edge connection strips to its right are what's shown covered by the bulging plastic part of the cover with COM on it as seen through https://jacksonsystems.com/wp-content/uploads/2023/11/12977.png
The included printed "manual" is https://jacksonsystems.com/wp-conte...ell_WT8860_Installation_Instructions-Copy.pdf
It has very minimal information under Wiring section on page 5.
Unclear where the 2 RTD wires are to be connected to on the new WT8860A1000.
Requesting help to identify where to connect the 2 RTD wires to.
Here's how I go about with my "guessing"...
First, I tried to draw some analogies by looking at one of the currently/still offered BW models, https://forthepro.bradfordwhite.com...a-low-nox/ultra-low-nox-atmospheric-vent-gas/
Its corresponding Service Manual is https://s3.amazonaws.com/bradfordwh..._vent_naeca_compliant_servicemanual_51546.pdf
Some of the small pictures give some clues. Unfortunately, as the small pictures have low resolutions and were not captured from a clearer/better angle, there's still some ambiguity to correctly ascertain.
For example, on page 16, it seems the 2 wires are connected to molex pins 1 and 2 (based on numbering shown on https://www.kit-elec-shop.com/19751...le-6-pin-connector-with-6-female-contacts.jpg).
In the picture I attached above, those are the lower-right 2 molex pins, closest to and right above the board.
The above assumes that the circuitries are consistent/similar between different logic boards for various Bradford White gas control valves. I don't know if that's a good assumption.
Hoping some folks here have other information/experience to help identify, maybe the technical documentation showing the pin-out and description of what those molex pins are for, just to be sure?
Many thanks in advance and good night!
