Hello everyone,
I have a leaking shower drain, which is not easily accessible from below. I have removed the old brass drain, and bought a Wingtite. Upon inspecting the pipe, it looks like there is a small gouge (probably 3/64" deep), around the area where the O-ring would sit. Now I'm concerned that it would cause a leak in this area, since the O-ring might not be able to seal properly.
My question is, should I put a thin layer of 100% silicone on the pipe, before installing the Wingtite? They recommend using dish soap as a lubricant to help the O-ring slide. I think fresh silicone would help with that as well, and might help sealing the surface imperfection.
Any drawbacks with this plan, or advice?
Thanks
Thanks
