Will my shower system work?
manny_ope
Indianapolis, IN
I'm plumbing a master shower remodel for quite a large shower and want to make sure I won't be biting off too much.
The master shower is on the third floor with about 40 ft of 3/4" PEX runs from the water heater and cold line. All runs will be with PEX-B and my general water pressure is always 75-85 PSI.
At the shower, I'd like the main lines branch into three circuits.
Circuit 1:
Branches off the main line with 3/4" PEX to the Kohler Anthem K-26339-NA thermostatic valve. From there, it travels via 1/2" PEX to 4 body sprays taking 1.75 GPM each connected to each other via a square loop.
Circuit 2:
Branches off the main line with 1/2" PEX to the Delta R10000-UNWSHF mixer with the 17T thermostatic cartridge and then the R11000 6 setting diverter. From there, it branches to 3 fixtures taking 1.75 GPM, 1.75 GPM, and 2.5 GPM.
Circuit 3:
Branches off the main line with 1/2" PEX to the Mr. Steam SpaH2O electronic valve. From there, it branches off to two fixtures, one taking 4.6 GPM and the other taking 2.5 GPM.
I'm a bit confused how to calculate pressure drop and whether everything would work together.
I'd never use all the fixtures at the same time, but at most, I'd use the 7 GPM body sprays from circuit 1, 2.5 GPM from circuit 2, and 2.5 GPM from circuit 3 for a total of 12 GPM.
Ideally, I'd want 1" PEX coming to the shower, but that would be quite a bit deal to redo.
I'd appreciate suggestions to my plan and some insights on whether or not my 12GPM max flow would work.
Yes it'll work fine. You have plenty of pressure. Pex a would be slightly better as the fittings on pex b are so small. But using two shower valves is a good idea.
