I think you guys are referring to the visible silver solder that is globbed on the joint (looks like glue)
I did use flux and heated both the fitting and pipe well. I held the torch on one side and applied solder to the other (didn’t apply solder directly into the flame). So the joint was hot enough to suck in the solder on the opposite side from the flame.
Once that was done, I kept adding solder just to “make sure” the joint was solid. That part was probably unnecessary and is what you guys are commenting on. If I had stopped after the first part, these joints would probably look perfect.
There is definitely solder in the joint. I tried to tighten one fitting with a pipe wrench after holding a torch on it and it would only turn for about 1 or 2 seconds after removing the torch. Then it was stuck solid together once it cooled just a little bit. This was all before I added the “extra” solder so it was just the solder in the joint holding things together.
