Which pvc fittings for vents?
Thekid1
Long Island, NY
I am piping out a vent setup for 2 basement baths. I see that home depot sells long radius, regular, and short radius fittings.
1) Which of the 3 should be used?
2) When using tees for the vents, should I be using combo fittings, sanitary tees, or just regular tees?
wwhitney
Berkeley, CA
For vents you can use anything. That is, as long as you don't create a mid-vent low point that would trap condensation; condensation always needs to be able to drip back towards a drain.
Cheapest and simplest will likely be to use just regular quarter bends and sanitary tees, but you could use the other options if they provide an advantage. For example a vent 90 has a really tight radius, which occasionally is useful.
Cheers, Wayne
Thekid1
Long Island, NY
Cheers, Wayne
Thank you. I was thinking to use long radius elbows and combo tees. Am I gaining anything by doing this or am I just wasting money? I was thinking it would be less restriction when pulling/replacing air?
