What product to replace under sink, dual stop compression fit on Pex A?
CBme
Kirkland, WA
Water alarms went off last night letting me know that the only stops I hadn't replaced had started failing. I've already replaced all the crappy multi-turn angle stops in our ~22 year old place with 1/4 turn Dahl compression fit stops but they were all on copper stub-outs. I hesitated on replace these under the kitchen sink that were directly attached to my PEX A as I couldn't decide what to use, and no Dahl or Brasscraft KT product seemed like 1:1 replacement, but I have run out of time.
The part that is throwing me is that they used compression fit connections and I don't see those being a listed product for Pex currently (and I wouldn't prefer them anyway as the neighbor's popped off a few years in). Builder's finish people were terrible, so I'm not sure if this is a thing. I don't have a Pex A expansion tool but do have a compression rings and crimper so I thinking of just finding some Pex B style stops but can't seem to find a straight replacement. For the dual stop, I don't care that much if it is a dual stop or single stop with dual out. I'd prefer not building a multi-piece solution if there is a good single part that I can't seem to locate.
I'd appreciate any recommendations!
Breplum
Licensed plumbing contractor
San Francisco Bay Area
I would recommend using Sharkbite type push on x male threaded adapters, then screw on Dahl or other reputable brand.
It is a completely pathetic stub out in pex that you have, but ....what ya gonna do?
Stub outs are ideally adapted to copper before exposing, that would have been ideal.
CBme
Kirkland, WA
I'm not keen on using sharkbite style products in permanent locations like this on the second floor where even a relatively minor leak would result in a huge repair effort, but I like the idea of considering an adapter to attach to the pex instead of just looking for dual valve (and single) that will work directly with it.
If you want to pretty up the stub outs, and provide a little extra rigidity, they make chrome plated sleeves that slide over 1/2" PEX. I've not actually used them, so I'm just assuming on the rigidity. E.g.
Cheers, Wayne
Interesting. That could make this spot look a bit less aesthetically janky (even though it is in a spot it can't been seen) but I'd be concerned about this looking bad/rusty in a few years like a lot of chrome plated escutcheon do.
I dont see a problem with a compression stop thats what my house has ? My issue at my house is there is no extra pex sticking out if I need to cut it for a fresh connection Im screwed . But youve got 6 inches to play with no problem buy an anglestop put it on . part number ktc1901dvx brass craft for the hot
wwhitney
Berkeley, CA
So can you use a general compression fitting on PEX? If so, what steps do you need to take to do so? E.g. use a stainless metal insert in the PEX to keep from crushing it, change the brass ferrule to plastic ferrule, etc.
Cheers, Wayne
CBme
Kirkland, WA
If that were my home or I were selling you a service that I had to warranty, I would recommend crimping a PEX x MIP adapter and installing Threaded straight stop / Threaded double stops.
Thanks! That is what I'm looking at currently as I prefer to have a replaceable stop without needing to cut the pipe back further should it need to be replaced. I just had blinders on what I was looking for so I didn't even realize FIP/MIP connected stops existed.
I see that there are some brasscraft KT and Dahls but I do not see any double valve or single valve double outlet option so may need to look at a T and two separate valves.
Tuttles Revenge
CBme
Kirkland, WA
No name brands might be just fine but do cause some concern due to the unknowns, especially as water is fear #1-5 in our house after all the issues we and my association neighbors have had. I don't see that thrifco part available to buy anywhere and for both parts, the companies that are selling them are US based but neither talk about where they are made.
I found that Dahl does sell a package that includes a pex crimp to dual mips adapter that would save one piece vs pex to single mips to a T but they didn't reply about anywhere that sells it locally and supplyhouse is backordered. They don't list that adapter separately.
Tuttles Revenge
I found another one .. Crimp on valve with 2 outlets. Guess its not really replacable without cutting pipe tho.
Or perhaps a single straight stop with a stack on tee splitting the 3/8 outlet
Or another version of the Dahl setup..
Cheers, Wayne
Thats the way my home was built and many others. Ive replace anglestops mine has brass ferules and ss insert on the PEX.
I see the OP has compression stops on the PEX 22 years dont know what his complaint is just needed new angle stops I thought . mine too 22 years old Ive changed angle stops here just because they werent funtioning so good or I gutted and re modeled a bathroom
CBme
Kirkland, WA
I went to local plumbing shops and no one had Brasscraft KT fips straight connection, only right angle. They didn't have any dahl or other quality brand/model either. One shop said they do carry the missing brasscraft part I was looking for but their overall stock of parts has been and is expected to continue to be low.
Then I found that supplyhouse had one of the multi-part dual shut-offs in stock, one with straight shut-off at top instead of the right angle that was backordered. As that will work, and nothing is available locally, I just ordered it and will go without hot water at the sink for another few day (I was able to shut off the valve and reduce the leak to only a few drips a day).
Weekend Handyman
Active Member
Nova Scotia
Pathetic but common … at least in my area.
It is what it is Galvie stub outs copper , cpvc, or pex not the end of the world the worst are cpvc my opinion but the others are very workable. my pex stub outs I dont like but hardly a problem Id rather the whole house was copper but its not no big deal (yet).
Weekend Handyman
Active Member
Nova Scotia
I agree … here is the last ones I did :)
