Civrel
A while back I purchased a Hach5B Water Hardness test kit. My softener started to give me problems again so I thought lets test the water inside and out. I took a sample from the pump faucet and followed the directions on the test kit and after 100+ drops, the solution had not changed from pink to blue.
I thought well, bad reagents and tested the water post softener. After 1 drop the solution changed from pink to blue.
If the solution did not change color after 100 drops, I would have over 100 GPG, probably likely.
If I dilute the outside sample 50% with water from the RO filter and retest, and assuming I get a color change with fewer than 100 drops, can I multiply that number by 2 to get the total hardness?
