GoldDiamond
Hello! (This is my first time installing a water softener, so please excuse me if these are dumb questions)
I am installing a new water softener in place of one that was already in the same spot. So there is the 1"? water pipes that come out of the wall .. and then the copper tube that hooked up to the wall pipes and ran to the bypass valve on the water softener is where the previous ground clamps were. (see pic below)
The new 2 ft. pipes that i got are corrugated stainless steel, can i put the ground clamps on the stainless steel, or do they need to be connected to copper? If they need to be on copper then i was thinking of hooking them right where the pipe comes out of the wall (only about 2 in of pipe there), is that a okay spot?! (see pic below, you can see where i took a razor blade and made it bare copper)
Im not even sure the 2 ft. stainless steel pipes will be long enough so i might have to use the old copper ones but i was concerned about the 2 different bends in the pipe and was wondering do you think they would be a issue (are the bends to severe)? I attached a few pics below.
Thanks for your help!!
Pictures:
https://imgur.com/a/47h3Mvc
https://imgur.com/a/CP50G3x
https://imgur.com/a/iGnpusR
https://imgur.com/a/HrZ59jJ
https://imgur.com/a/2XT4zav
https://imgur.com/a/2VWNiYM
Pictures:
