water line on exterior wall
Tameria11
Ontario
Hello
First, I would like to thank everyone that has been helpful to my questions so far, Great stuff.
Do to our restricted layout, I will be forced to run water lines through my exterior wall in the basement for our new bathroom. I want to drywall the ceiling to keep some height, how do you insulate the wall to prevent freezing the pipes. It gets very cold where I live,-25 is not rare!!.
I am getting discouraged with this reno( 1 step forward-2 steps back and would love some positive advice.
Should I work at another design lay out. I am going through the slab this week, so I don't want any problems with water lines freezing up...
Thanks
Dave
Leejosepho
DIY scratch-pad engineer
www.nonameyet.org
Water lines below the frost line will not freeze, and I believe that fact usually makes lines on the inside of basement walls safe. I have water lines fastened to the inside of the walls in my basement with framed and insulated walls sitting just a few inches out.
Tameria11
Ontario
inside walls
not quite clear what you mean. Do you have your water lines behind the drywall going through the studs, and how do you connect to the shower head, it will be above the frost line?
Gary Swart
Yakima, WA
Are you saying your basement is totally unheated? Usually enough heat from the house gets into a basement to keep it at least above 32. I don't follow what you mean when you say the "drywall on the ceiling will keep some height." Do you mean heat? I would not cover the pipes with insulation because insulation does not add heat, but drywall is not a very good insulator although it will slow the rising heat somewhat. So, insulate the basement wall then run the pipes on top of the insulation, and finally drywall. If all else fails, put some heat down there!
Leejosepho
www.nonameyet.org
Please pardon me for not being more clear. About half of my basement is below the frost line, and the relative "warmth" that radiates up from the lower half of the basement (even along the walls) is enough to keep pipes that are fastened to those walls from freezing.
Maybe this picture will explain things a bit. Even after the framed wall is insulated, the water and drain lines along the wall are not going to freeze unless the entire house ends up being unheated and freezes.
