Basement floor vent-- are you saying that there are registers in your basement floor that normally blow warm air into the basement to heat the basement?
Are the vents that you are talking about metal, and are buried in the basement floor concrete?
Or are you saying that there are vent pipes above the concrete, but the water level has risen enough to seep into the metal duct?
Your water table may have risen. The pipe that feeds the foundation drain water into the city sewer may have clogged. The city sewer may be saturated and the standing level may have risen; do you have a basement floor drain where you would have seen a backup if the sewer had risen to that level, or is there a drain in that basement low spot that now has standing water?
To answer your questions:
1) Yes, there are registers on the basement floors.
2) Yes, they are metal vents buried and encased in the concrete floor.
3) No, we don't have vent pipes above concrete that water is seeping into. We had a good look because it could have happened in the basement bathroom, but it didn't.
4) After reading your comment, we measured the water level from the floor drain and it's 10 inches from the top of the water to the top of the floor and we measured inside the furnace and ductwork, where the water is and it's 11 inches from the top of the water to the top of the floor. We emptied the duct work and it has since filled back up today with the same clear and brownish water. Again there was no sewer smell.
5) At this moment we don't have sewer back up problem.
In regards to your comment about the water table and the city sewer, we feel that we have to give some background information on the property. We've been living in the house over twenty years. Last spring was the first time we encountered a minor sewer back up and it only flooded one inch in the laundry room around the drain. We failed to unplug the main line with a rented auger/fisher. We had the city come and checked the sewer with a camera. It unplugged with the camera and they told us that some new Aspen tree roots were seen by the camera. Last year was also the first time in twenty years did we have water in the ductwork. Back in January we had another minor back up again that we successfully unplugged with a auger/fisher. We don't understand the connection with the sewer/weeping tile and the water in the ductwork. The water that we pumped out from the ductwork was not sewer water, it was clear and brownish sandy colored water, there was not any smell, except an earthy smell.
How does the sewer, weeping tile and ductwork related to our issue of water under the furnace? It feels to us that there is a build up of water under the house. Can you explain this connection of the sewer, weeping tile and ductwork?
It seems to us this will be an ongoing issue in the future. We can't run the basement furnace during these periods and we need a permanent solution to this new issue. Do you have any suggestions or direction?
Thank you so much for your insights.
