straightexhaust
Hey all,
I have included an image of two sketches that I made. The bottom sketch is the way that I am used to seeing backwash lines give or take the studor. The top sketch is what I would like to accomplish which is to tie in the drain lines into the discharge line of my sump pump. I am trying to save all of this water going into my drain fields. In the sketch you will see where I am confused as how to proceed as I think a check valve is not code and would also fail over time and the air gap fitting is not feasible due to the line being under pressure from the pump discharge.
I have three drain lines that I am trying to terminate, one for my softener, oner for my neutralizer and one for my sediment filter. If you can advise me on a solution for the above mentioned tie in, I am assuming the each line would need to terminate separately. However in my thinking there would be no "contamination" but would there we a pressure issue from say the softener to the other units if it wash backwashing and vice versa. Correct me if I'm wrong but i'm thinking that the piston in each head would protect from backflow. I also want to avoid running the lines into the pump basin because I rarely ever have ground water coming in so all of this backwash would fill up and go into my drain tile before the pump float actuated and I don't want that around my foundation anyway.
Thanks for your insight.
Jason
Jason
