I've read quite a few threads here about upgrading washing machine supply lines, and whether using PEX means that a bump-up in diameter is needed. I am going to be running PEX into my addition, and was thinking about leaving the 3/4" supply all the way to the laundry room. When looking at washing machine valves/outlet boxes/etc, I see almost everything labeled washing machine this or that is 1/2" supply into the valve, with 3/4" male hose threads for the washing machine hoses. Why is that? Does it matter when the supply of 1/2" regulates the flow to the valve? If all machine manufacturers have hose hook-ups for 3/4", why do valves seem to mostly be made for 1/2" supply? A million questions I have, but are the options for supplying the laundry with PEX going to be limited?
An additional question I need help with, if I was going to put together my own configuration, than say buying an Oatey outlet box, are the valves called something special, like boiler drain valve, or does any shut-off valve qualify for laundry applications? Some I see listed as being for 'low water pressure applications' - does residential qualify as low? Thank you.
