Kilgore Trout
either pull out the old box and repipe the water, or use your drill and drill the holes for your water wherever you want them to be. Personally, I prefer the style with the single control.I can't find a comparable model. Want to replace the outlet box.View attachment 44931
I'm fixing for my mom, haha once I tell her we have to rip out the wall she'll freak.either pull out the old box and repipe the water, or use your drill and drill the holes for your water wherever you want them to be. Personally, I prefer the style with the single control.
How about DEFENSE and DEFENCE?Are you kidding? Nothing compares to a Catch-a-Drip. Keep it.
Thank you very much for knowing the difference between "advice" and 'advise".
Folks with plumbing problems don't seem to know the difference.
Could there be a connection?
Same word, different spelling. Advice is a noun and rhymes with lice. Advise is a verb and rhymes with pies. If you need advice someone will advise you. Pet peeve. My mother was an English teacher. I still carry the scars.How about DEFENSE and DEFENCE?
Water flow & drainage work just fine but the box itself is corroded and rotting out.If the old one works, how about contact paper or paint?
if its just corroded and rotting out and you want a quick fix, get a little bit of WHITE porable epoxy. use it to paint the interior and pour in about 1/8" into the bottom to form a permanent waterproof bottom.Water flow & drainage work just fine but the box itself is corroded and rotting out.
Maybe put a big rubber stopper into the drain hole before attempting this or something similar. https://www.sciencecompany.com/Black-Rubber-Stoppers-Size-Chart.aspand pour in about 1/8" into the bottom to form a permanent waterproof bottom.
Thank you for the advice.Maybe put a big rubber stopper into the drain hole before attempting this or something similar. https://www.sciencecompany.com/Black-Rubber-Stoppers-Size-Chart.asp
I might clean out what is loose enough, with sand paper, scraper, or whever. Then POR15 or similar. That will control the rust. Then a coat of for appearance paint, masking to control the paint.
Some people even refinish countertops with a heavy contact paper. They usually use a granite pattern for that. Try this search in a search engine if you want to see that:
countertops "contact paper"
Another idea: Remove the bezel. Clean and refinish the box interior, and clean and refinish the bezel separately. Restore the bezel. Maybe a matte black or dark gray finish in the box would hide imperfections, and the light colored bezel would get most of the notice.
I'm pretty sure he did. I've been doing various repairs at this house over the years and it's always something out of the norm and overly complicated but mostly lacking any kind reasoning. Don't even get me started on the electrical aspects of this house.Then, kick it to the curb and install a new one. The pipes coming in from the sides is a worrisome thing to me. Looks like the original installer had mental issues. I can't picture a situation where I would feel compelled to run the pipes into the sides of the washer box. Makes no sense to me. If he's fishing for the Golden Pipewrench Award 2018, then he's missed the mark.
By the way, are you related to cutthroat trout?
DEFENCE and DEFENSE are different spellings of the same word; yet belong to different forms of the English language. Defense is used in American English, and defence is used in British English, which spans Australian and Canadian English.How about DEFENSE and DEFENCE?
