Unsure which Grohe model and the shower is too hot
pb2501
PA
Hello all!
I just bought the house and the shower temperature is too hot no matter the location of the temperature control knob. I am unsure what model of Grohe this is.
The water heater temperature was set too low when I moved in. The water was only getting luke warm thoughout the house. I increased the water heater temperature. The faucets throughout the house can now get hot. The only problem now is that the master bathroom shower is way too hot. I thinking that the temperature control valve needs to be recalibrated.
Also how do I remove the handle?
Thanks in advance.
Marlinman
Jacksonville Florida
Their is 2 different valves used with this trim. You will need to confirm the pipe size
3/4 " valve 34124000
1/2" valve 34122000
Trim Seabury 19614000
  • 34124000.pdf
  • 34122000.pdf
  • 19614000.pdf
pb2501
PA
Thank you! There is a screw on the handle that is covered by a threaded ring.
