Toto MS980CMG Neorest 550 lid motor failing
brian hood
Seattle, WA
Hi everyone,
I have a Neorest 550 installed in 2013, the lid fails to stay up about 30% of the time. Tech support says the motor is going out and needs to be replaced, the two options offered are sending the top to them ($450) or having a local authorized plumber stop by (cost unknown). The CSR said that this is work he does himself and that it it easy but that parts are not available. I have a lifetime of experience in the construction trades, hundreds of tools, and typically do my own repairs.
I wonder if there is a source for those motors anywhere?
Thanks for any help provided,
Brian
brian hood
Seattle, WA
To be more specific the part number of the toilet is CT980CMG, in Cotton white.
SOPAS
California
Hi Brian, I was wondering if you ever did anything with this problem lid? Can you share what your resolution was as I have the exact same problem installed the same year!
Tuttles Revenge
The repair can only be done by the factory in California or by an authorized field service tech. No parts are available to purchase from any third party.
esuvee
Michigan
Found this while googling for a solution to the same problem and figured I'd chime in with a solution for anyone in the same situation.
Super old school but I took the lid motor out, removed 5 tiny screws from the big end (need a specialty electronics screwdriver kit, the size is PH00), removed the small brushed DC servo motor, and then sanded the contacts and commutator like it was 1950:p
You have to pry open the clasps on the metal motor housing which is risky for running a pick into your finger but otherwise this is super simple.
Worked like a charm!
Alex
Tuttles Revenge
Alex
Nice job! I wish I'd held onto a few of those old motors when I was replacing them.
