Rossn
I have a surface drain system around my home for gutters, given I can't grade it properly. It is constructed of 4" SDR35 sewer pipe.
I need to tap into it for a new stand pipe, and given it is buried, the options I see are:
Which of these is the better option, or is there another approach I should consider, which may have better longevity?
- use a 4"x4" rubber saddle fitting (Fernco)
- cut a section of pipe out, and replace with a section that contains a tee, using a rubber 4" coupling on each end.
