Mev
I have the Sense Monitor and application so I can trace appliance electrical usage. I've searched the titles in this forum, but could not find a match to this problem.
State HPX-66-DHPT installed in basement, lows 60s year round, tank temperature set to 125 degrees, whole house soft water conditioner.
Installed 10/20/2020. Worked perfectly in efficiency mode for almost 2 years. Would run for 1-2 hours per day on average to keep temperature in the tank around 125 degrees. A couple weeks ago I noted that it was running for over 4 hours without a change in water usage (one person living in house). Installer came out on 10/05/2022 and recommended that I switch to the default Hybrid mode which I did. Seemed ok until this morning. I used hot water the afternoon before, but none at night or today. The heat pump has been running now for 6 hours. Drawing around 1.2amps in heat pump mode.
Electric mode works so I have a backup.
Is there anything you can tell me to recommend to the installer to look into? Already paid for one visit.
Thanks,
Mark
Thanks,
Mark
