I'm replacing some ancient 4" cast iron pipe with 4" Sch 40 PVC. I noticed that the old cast iron pipe has a slight bend in it. If I run the replacement PVC with no bends, after about 10 feet I reach a joint where the pipes meet at around 83 degrees. Is it okay to flex the PVC pipe slightly to accommodate that weird angle? Would it be better to use a pair of small-angle elbows to adjust to the desired angle without flexing the pipe? Are there other solutions to this problem?
