Single to double bathroom plumbing
Kenzie133
North Carolina
Hello!
You guys helped so much when I did my kitchen sink. I’m back for help with my upstairs bathroom. It was originally a single sink and I want to convert it to a double. The for picture is the original plumbing. The second picture is what I was planning on doing. The third picture is also what I thought I needed but I’m not sure.
wwhitney
Berkeley, CA
Kenzie133
North Carolina
Either 2 or 3 works. In 2, the new fitting should be a 2x1-1/2x1-1/2x1-1/2 double fixture fitting, e.g.
3 looks tight as far as stacking all the fittings without moving the cleanout down or the existing san-tee up.
To connect the new work into the stack between fixed ends, use (2) banded rubber couplings, e.g. Fernco Proflex or Mission Rubber BandSeal.
Cheers, Wayne
Thank you! That’s the exact piece I was looking for but kept coming across, 2x2x1-1/2-1-1/2.
