Replacing vanity, need drain cleanout advice
Charles Mitchell
Austin TX
I tore out the cheap double vanity in my upstairs master bathroom and purchased a nice double vanity from the big box store. The wall has two sets of drain couplings and two cleanouts. The old drain placement was doesn't align for the new vanity. The vanity manufacturer recommends the drain coupling be at 18" from the floor. They are currently at 15 1/2" so I'll move them up.
The clean outs are about 5" off the floor. They will interfere with floor of the new vanity so I have to move them. How high can the clean out be? I can't find any requirement related to this. Can I just stack 2 sanitary tees and just place them so my drain height is right and the cleanout is above the floor of the cabinet? Or, any chance I can just eliminate the cleanouts and use the drain port if it needs snaking?
Thanks,
Charles
ATX
Cleanout can even be above the santee.
I think yes, and yes. I am not a plumber. Most people don't have a dedicated cleanout for a lavatory.
Mississippi
If you raise your trap arms you need to raise the connection point in the vertical stack.
Do not install fitting in the horizontal fixture arms to raise them without reventing back to the vertical stack. Without reventing you’d have created an s/trap.
Leave the fixture arms at 15” if it’s not interfering with anything. Even if it’s interfering it may be easier to alter the cabinets instead of raising the fixture arms properly.
I do not use AAV unless it’s absolutely necessary. Period.
Just raise your cleanout in the vertical. Cleanouts save money......
Charles Mitchell
Austin TX
I've cut the sheetrock out around the drain. It should be easy to slice in 2 new sanitary tees in the stacks. Above appears to be vent to roof.
I'm off to buy the tees, coupling a bit of 2" PVC pipe. Thanks everyone for you help.
