Repairing a pin size hole in plastic water line
which is best for rapairing pin size hole water leak on plastic line
  • a plastic shark bite coupler
    Votes: 1 33.3%
  • rescue/self fusing silicon tape
    Votes: 0 0.0%
  • Straight Barb connector
    Votes: 2 66.7%
  • J-B Weld 8277 WaterWeld Epoxy Putty Stick
    Votes: 0 0.0%
  • J-B Weld 8237 PlasticWeld Plastic Repair Epoxy Putty
    Votes: 0 0.0%
  • Yanyi Moldable Epoxy Glue
    Votes: 0 0.0%
  • other
    Votes: 0 0.0%
  • Total voters
  • Poll closed .
mcf57
GA, USA
So, I discovered a water leak on my Samsung fridge. It turns out to be a pin size leak in the water line feeding the icemaker and water dispenser. Since the line goes inside the fridge (from back), it would require tearing apart the inside in order to get to where the connection is on one end.
Therefore, I was hoping I could simply patch this plastic water line. Again, its pin size leak and was hard to find at first, but I'm glad I found it. After some investigation, I found some options & think I have the following ways to repair this REALLY tiny hole. They are as follows:
Which one would be best? Or any other suggestions? A Samsung water line replacement kit for this fridge costs $79 and would require tearing inside of fridge apart so was looking for a simple "patch" of some kind.
Tuttles Revenge
$79 replacement kit. If you're handy it will take a couple hours likely. We just installed a new fridge at our office and had to install the water system and ice maker. Dont mess with goofy repairs of soft tubing.
Only other option would be a coupler if you can get insert fittings to prevent the tubing from crushing.
