Jakester
Thanks for your help! When you install the Delta drain do you use plumbers putty or silicone?
.We have California Faucets Zero Drains in our master bath sinks. They push click down to lock. Seem to work and look nice. Heavy brass construction and a pretty durable finish. Easy to remove to clean out a hair clog.
They specify silicone for installation if you want a warranty on their finish.
http://www.calfaucets.com/zerodrain
The Delta box should have come with instructions. I'm scanning a set from a Brizo box on my shelf. They're the same manufacture so the process is the same.
https://www.brizo.com/bath/product/content-main/product-detail.FileHelper.do
But yeah.. the delta site had a link, but no instructions..
Its not bad manners to pull up old relevant threads to ask a relevant question.Hoping it is not bad manners to revive an old thread. Lot of good information here.
I am going to throw one other consideration into the discussion. I replaced one of the sink drain stoppers (delta brass pop-up with the pull rod system) and it had a little silicon gasket/washer. While I thought it was pretty cool that they had moved away from Plumber's putty, when I was all done with the replacement I was not a happy bird since that silicon washer now created an additional thickness where some water would just stay in the sink. The one that I had replaced was done with plumber's putty and that was very tight - there was really speaking no water staying behind in the sink.
In another bathroom, I had a Moen faucet installed and it came up with its own pull rod system drain. The flange piece that sits in the drain, as far as I can tell, is much thicker than the old Delta one that was replaced. So again the same problem - there is some water that accumulates due to the thicker flange.
I am now looking to buy some pop-up drain assemblies. Between Delta/Brizo, Kohler and Zero-drain, is there a recommendation on which of these has the thinnest flange that sits in the sink? And seems like plumber's putty or something like that is the way to install if one wants to avoid water sitting near the silicon washer. I did see zero-drain in a store but my fear is that the flange is a bit too thick.
I just opened up a Masco (the company that owns delta/brizo brands) push pop up that does have an opaque silicone gasket like you describe. Some of those are intended to fit into european spec drains which are a slightly larger diameter than US spec drain holes and will cause that gap as you describe. I would just remove that gasket and replace it with putty.
(wrote the following before I looked at the drain I have) The thick rubber washers are not meant to be installed between the flange and the sink. Often a soft neoprene / foam gasket will be provided for that purpose and it would smoosh down completely so that the flange will make contact with the sink. That gasket or putty is there to fill in gaps where the porcelain isn't perfect to prevent water from seeping into the drain when the stopper is closed.
Is this the delta pop up you installed? Or something similar?
I really like the Delta/Brizo (masco) push pop up assemblies. The mushroom topped ones I like for the larger european sized sink drains and the center pop ups I like for the US sized sink drains.
Was that a silicone gasket or a foam gasket? I see several different gaskets provided with pop ups depending on manufacturer and models. Most don't come with any gasket and those depend on plumbers putty being installed for that seal.FWIW, I bought a couple of these last year, the white gasket shown in the picture is super compressible and doesn't raise the drain flange. I was a little skeptical but gave it a try and haven't had any complaints.
Push Pop-Up with Overflow in Stainless 33W576SS | Delta Faucet
This Push Pop-Up Drain Assembly is simple to install, operate and clean. The Chrome finish is popular across all décor styles in the kitchen and bath...www.deltafaucet.com
Cheers, Wayne
I'm not sure I've ever seen a silicone gasket--since it was super compressible, it must have been foam?Was that a silicone gasket or a foam gasket?
Yeah looks like foam. But the ones that have encountered were silicon gaskets. And the one in my delta unit is not super-compressible - don't forget that there is another gasket below the sink - so when tightening too much, we are compressing that one too.I'm not sure I've ever seen a silicone gasket--since it was super compressible, it must have been foam?
Cheers, Wayne
