uscpsycho
Please see the attached chart of water heaters by AO Smith. All these water heaters have either 34 or 50 gallon tanks but each with different specs.
My question is regarding operating cost. Assuming water usage is well below the capacity of the heaters, would the lowest rated 50 gallon heater (GTP-130) be cheaper to operate than the highest rated 50 gallon heater (GTP-199)? Or would it be the same?
Based on my limited knowledge, what I think is that they will cost the same to operate. Since both have 50 gallon tanks the standby loss is the same for both but the 199 can heat more water more rapidly when the usage is higher. So you have the power there when you need it but if you don't use it, it doesn't cost you anything to have it.
Unless the GTP-199 is costing more to run even when water usage is low, could that be the case?
Thanks in advance guys.
