BAPlumber
What's below this tub? crawl space or another room (i see insulation)?
you just need to remove the tub, Install a left hand drain tub and move the tub/shower valve to the other wall. run the water through the joists below and back up or up through the ceiling then back down.
what are you doing with the tub overflow? Those are PVC water fittings, not made for drainage and also need to be removed.
