Scott McNab
Thanks in advance for any help. I recently had a propane boiler installed. Just trying to figure everything out and get the right settings. A little background. The circulation pump is controlled by the house thermostat and the boiler is controlled by a low limit aquastat. What temperature should I set the low limit and the differential (5 degrees to 30 degrees). Seems like a waste of propane this time of year keeping the water hot when the home doesn't call for heat that often. Daytime highs are around 7 degrees. Would an outdoor reset control be worth the money? The boiler is only used for home heating as I have a separate electric water heater. Just seems like it runs quite a bit. I'm used to an oil Boiler so maybe I'm overthinking things.
