Tim Pape
First post so thank you all for having me here. I just finished building a detached shop here in northern VA. It's two sections, a 32x48 with 9' ceilings and 12" poured concrete walls, and this opens up to an attached 40x40' with 2x6 framing and a 14' - 18' vaulted ceiling.
I poured the slab which is a continuous 2900 sq ft and broken up into the two zones above. I have 12 loops of 1/2" pex 10" apart in the 5" slab under a system designed by Radiantec.
What I am greatly struggling with is the heating source. Radiantec wants me to use a rebranded Takagi 199k BTU tankless condensing heater with a copper main exchanger and stainless secondary. My HVAC guy wants me to use a 199k BTU Navien tankless modulating boiler that will only heat as much as needed and therefore be less taxing on the unit. Navien is stainless on both exchangers. Boiler vs hot water heater...Is it better to have a boiler working a lot less than capable or a tankless that is running 95% of capacity much of the time?
I have a Navien tankless for domestic in my main home and love it and have had no issues whatsoever. Open to other brands though.
The floor system requires about 95k BTUs from a heat source based on calcs from Radiantec.
Any advice/recs are greatly appreciated. This is going to be a auto restoration shop so I'm only looking to heat the place to 55-60 degrees max.
The other option is the Navien Combi-boiler for the heat source and domestic water (one full bath and three utility sinks), but I need to check on the BTU capacity.
Thank you!
-Tim
Thank you!
-Tim
