plan for vertical wet venting the tub via the lav in the master bath
NSB000
Minnesota
The lavatory, WC and bathtub in the master bath are all independently dry vented (original construction 1965).
I want to wet vent the bathtub via the lav so that I can eliminate the tub's original drain and vent pipes (that gives me a pipe-free wall and would allow me to make unrelated remodeling changes). This wet vent plan appears to be doable after referencing Minnesota plumbing code (UPC) and reviewing related threads here.
I created an isometric drawing for the addition of the tub wet vent in the master bath. If a different depiction would work better, I can do that.
I think I can summarize the changes here:
- the vertical pipe for the lav (drain & vent) is currently 1-1/4"; all of the 1-1/4" will be removed and replaced with larger diameter pipe
- the tub trap arm is currently about 1 ft long using 1-1/2" pipe; the new tub trap arm will be about 52" long using 2" pipe
I have done my best to ensure the changes comply with the UPC for Minnesota.
I hope I didn't neglect or overlook anything in my plan. Any feedback to get the plan right is welcome.
changes to be made:
- increase pipe diameter of vertical dry vent section above lav santee from 1-1/4" to 1-1/2" to accommodate 3 DFU: lav (1 DFU) + tub (2 DFU) (table 703.2)
- increase pipe diameter of vertical wet vent section below lav santee (and above tub santee) from 1-1/4" to 2" (section 908.1 Size (for wet vent))
- insert tub santee (2" x 2" x 2") below lav santee
- increase pipe diameter of vertical drain pipe below tub santee from 1-1/4" to 2" to accommodate 3 DFU: lav (1 DFU) + tub (2 DFU)) (table 703.2)
- change direction of tub's trap arm 180 degrees, away from the wall and toward the lav drain
- change tub trap arm pipe diameter from 1-1/2" to 2" since the distance from the redirected tub trap weir to the lav drain pipe will be 4'4" (52"; greater than 42" and less than 60"), [table 1002.2]; 2" trap arm pitched 1/4" per foot
- change tub trap ID from 1-1/2" to 2" [section 1003.3]
- replace original lav santee with 1-1/4" x 1-1/2" x 2"
- cap off abandoned tub santee (original drain & vent pipes to be removed)
Looks good.
If you are replacing the lav san-tee, you might use a 2x1-1/2x1-1/2. Then at the wall you can use a 1-1/2" or 1-1/4" trap adapter as desired.
Note that the trub trap arm may fall at most 2" (one trap diameter). 52"/48" = 1"+, so it will work if you stick with 1/4" per foot slope you indicate. But if you exceed that slope, you need to stay under 1/2" per foot.
Cheers, Wayne
Thanks for the input. Great recommendations. I will replace the lav santee as you suggest with 1-1/2" at the trap arm inlet. And I will ensure the drop of the tub trap arm does not exceed 2".
yea no one uses 1 1/4 on homes unless there is some reason like fancy trim . except on RV or mobile homes
