Noise in PVC DWV Pipes
ThreeNephews
When hot water drains from my sink or tub in the upstairs bathroom, there are noises coming from either inside the DWV pipe, the drywall or the wooden support structures. I’ve talked to several plumbers who’ve never heard of this. Has anyone else ever experienced this?
Casman
New York
Ya, this is very common and is usually expansion and contraction and the friction between the points of attachment. Mine sounds more or less like a popping or ticking...
Casman
New York
No, I suppose I could but I think i would have to open the wall, which is behind a 6 foot long vanity.
ThreeNephews
Well, in my case the wall is already opened because I had to re-pipe the supply lines (I had the infamous grey plastic stuff used in the 80s - 90s). Luckily, I can see exactly where the pipe is jammed in tight between two studs. So what I'll do is re-enforce the studs with metal braces then chisel out (or something) around the pipe.
