New Kitchen Sink/Drain Height Challenge
Treeman
Active Member
Michigan
My son is installing a deeper single drain sink and is requesting ideas for proper connection. See the attached picture. Thank you all for assistance.
Tuttles Revenge
There is a disposer direct connect WYE that connects directly to the basket strainer.. That will save a small bit of room, but it looks like you would also need a Reverse P-Trap.
Treeman
Active Member
Michigan
Thank you. Can you show a picture of the disposer direct connect WYE please?
To me, the wall drain seems exceptionally high. A shorter sink drain strainer would yield an extra inch or two.
I did find this thread from Terry (RIP, dearly missed) that shows the reverse P-Trap: https://terrylove.com/forums/index.php?threads/drain-too-high-or-sink-too-deep.80965/
This gives me some ideas. Thank you so much. Sincerely appreciated.
In addition to other considerations., you will need to add a bend, such as 45 degrees or 22.5 degrees to aim the trap closer to the tailpiece. That wide-U trap in my avatar is not a real thing.
Treeman
Active Member
Michigan
Thank you for reminding me of that.
This picture from more directly in front shows that we need to address both the height and side distance change.
For others that might wander into this thread with similar challenges, I DID find many other threads covering this topic (should have searched better first). To move the wall drain lower would be a LOT of work - it turns sideways horizontal thru the studs and connects to a vertical vent pipe.
Attached are clearance adding solutions: a thinner sink strainer, a tailpipe with higher dishwasher drain, the direct WYE Tuttles Revenge mentions above, a reversible j bend, and a shallower J-bend: hope this helps others. Thank you everyone.
