New Construction 2nd Floor Plumbing Question(s)
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Kenny4, Jul 15, 2018.
  1. Kenny4
    Kenny4 New Member
    Jul 15, 2018
    So Cal
    SANY1488.JPG SANY1495.JPG New to this site, so hello to all. I'm drawing plans for a small 2 story in So Cal, (these are just napkin drawings for this conversation). My question will have to do with the upstairs plumbing. I have shower, toilet and 2 vanity sinks all in a row on the same wall, (will try to add a pic). The downstairs wall under this has a 4' 2x6 wall at each end with a 16' beam between and floor trusses on top of that. The trusses will bare on that wall so plenty of open chases. The problem is that the vanity drain wall would be right on top of that beam, so would have to be rerouted. Let me try to get the pic up, so what I'm saying will make sense. Thanks, Kenny
  2. Kenny4
    Kenny4 New Member
    Jul 15, 2018
    So Cal
    Sorry about all the pics, my first post, I guess I hit the stutter button. Not sure how to remove the 2 duplicates. I n the pic of the upstairs the floor trusses will run parallel to the stair well with the ends resting on the same wall as the plumbing, and should be 24" oc. The 4' wall is 2x6 so could be used for main drain. Directly under is 16"-24" crawl space, (depth of truss not determined yet), so at 1/4" per ft there seems to be plenty of room to reach the 4' wall. It seems the shower and toilet should drain easily to the 4' wall. It's just the drain from the vanity sinks that I can't visualize, and need help with. Thanks
    Kenny
  4. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    To make changes, click Edit. If you want to delete or replace a picture totally, click More Options...
Similar Threads: Construction Floor
Plumbing Forum, Professional & DIY Advice Floor Drain Under Furnace in New Construction Home? Feb 12, 2018
Plumbing Forum, Professional & DIY Advice Identify floor drain in new construction Sep 9, 2017
Plumbing Forum, Professional & DIY Advice New Construction Stub Out Friday at 11:02 AM
Plumbing Forum, Professional & DIY Advice New Construction Plumbing Vent Issue Jun 28, 2020
Plumbing Forum, Professional & DIY Advice Vent, tub, shower, new construction Feb 7, 2020
