Charles Stork
My old 13 yr old Fleck 5600 Econominder went out recently per my service provider and he recommended a newer upgrade different replacement softener system for small fortune. I went online and purchased a new Fleck 5600 SXT 80K system instead for much less. I installed it myself yesterday per the Fleck installation instructions with no apparent problems or leaks. I have the following system info and parameters set on the new system.:
System info (not programmed)
salt lb/cuft = ???; prefer salt efficiency
BLFC = 0.5 ; Brine Refill rate GPM
DLFC = 5
Injector size = 3
cubic ft resin = 2.5
Raw hardness = 68
Iron = I believe 0.00 or very low since a couple of tests I took did not indicate any so far.
Manganese = ??? Will try to have test done soon.
People = 2 (occassionally our 2 college kids come home on weekends and we wash cars with softened water)
Estimated gal/day = 120
Estimated days/regen =
Current Fleck 5600SXT Settings:
DF = Gal ; Units
VT = dF1b ; Downflw/Upflw, Single Backwash
CT = Fd ; Meter Delayed regen trigger
NT = 1 ; Number of tanks
C = 50.0 ; capacity in 1000 grains
H = 68; Hardness-- compensate higher if needed
RS = SF
SF = 10 %
DO = 7 ; Day Override
RT = 2:00 a.m. ; Regen time (default 2 AM)
BW = 10; Backwash (minutes)
Bd = 60 ; Brine draw minutes
RR = 10 ; Rapid Rinse minutes
BF = 10 ; Brine fill minutes
FM = t0.7 ; flow meter
Since I am a novice on softener programming, I am wondering what if any adjustments I may need to make. Your help is appreciated.
DLFC = 5
Injector size = 3
Raw hardness = 68
DF = Gal ; Units
RS = SF
SF = 10 %
