John Z
My boiler is in the garage, which is where I do a lot work and sometime require a couple of gallons of hot water. I would like to be able to get the hot water directly from the boiler. The boiler supplies both heating and household hot water. It has an expansion tank.
1. Can I open the pressure relief valve and get water from its drain pipe?
2.If not, where is the best place to tap in and install an garden hose valve? The hot water line from boiler to house?
3. The hot water supple line from boiler to the house has a adjustable (calibrated) pressure relief valve (photo). It is dripping very slowly. I am planning to replace it with a Watts 530c (1/2"). What psi should I set it to?
Thanks in advance!
Thanks in advance!
