Hi, I have a MITW50L6EN12 Bradford White Thru the wall venting water heater.
I have been having some problems with it lighting to heat the water intermittently.
This unit has a glow plug, thermocouple and pilot light. When it calls for heat the flue blower comes on, the glow plug turns on which lights the pilot light and then the burner comes on.
It works fine for maybe a week or a month and then it will skip a beat and not light. When I go to check on it, I find the the blower motor is running, the pilot light is lit, but no burner on. If I unplug the unit and plug it back in, it will then cycle the right way and the burner will light. It may work ok for a few days, a week or a month.
Last time this happened I replaced the glow plug and thermocouple set with new ones. It lasted about a month without the problem, but it started up again yesterday.
Not sure which to try next. I know some of the other parts for this unit are a separate thermostat, a water heater pressure switch that closes when the proper air flow is achieved, a high limit thermostat, and the gas control valve.
Any ideas on why this is happening and which part I should try next?
Thanks for any and all replies.
Carl
Carl
