Need help choosing a water softener system
ajcrm125
Western MA
Been suffering from hard well water since we built our house 10+ years ago and decided it's finally time to get a softening system. A bit overwhelmed at all of the options out there however. For some reason I thought there was a site where you could input your water test data and it would suggest filtering/softening solutions?
Anyways my report shows the following. I assume the units are mg/l?
Hardness 332.0
Total Dissolved solids: 298.3
Soidum 6.79
Potassium 2.8
Magnesium 4.4
Calcium 129.6
I can vouch for the calcium. That seems to be the biggest factor.
So any recommendations on a whole-house softening solution?
-Adam
How about these numbers?
Iron
Manganese
pH
Arsenic​
Also, are there any other values where the reported number is 50% or more of the MCL shown on your report?
ditttohead
Water systems designer, R&D
Ontario California
It is important to have a real water test done prior to doing water treatment. I would recommend Kar Labs or NTL Labs. Simple, reasonably priced and very comprehensive testing.
ajcrm125
Western MA
Right the test was done from Quabbin Analytical Labs here locally. Being right next to the reservoir I'm lucky enough to have a lab pretty much next door. :)
Some of the other requested values:
Iron 0.03
Manganese 0.07
Ph 7.74
Arsenic 0.00189
I'll look at the report more and see if any values jump out.
Pending other info that develops from the rest of your test results, a softener 1.5 cubic ft of resin is what would be good for you.
Nice water. I would put a sediment filter before the softener myself. If it stays clean, it still served a QC purpose IMO.
ajcrm125
Western MA
Yeah I have one today and it works really well.
@dittohead any insight based on my report?
ditttohead
Ontario California
A softener only, since you are on a well a Hydra just as a junk catch, other than that your water looks great.
