Navilink Lite & NPE 240A
bobryan
Scottsdale, AZ
I have a Navien NPE 240A about 3 years old and decided I'd like to try Navilink Lite for better control. Connected the Navilink Lite unit and WiFi is showing steady blue light and com lite is steady red. The problem is that the app is showing "no products are connected to navilink". Am I missing something?
GReynolds929
WA
The instructions indicate that there are parameters that need to be set for it to be recognized. Specially on page 12, p.18 needs to be set to on. Has this been done?
estripem
Southwest Ranches, Fl.
I followed the setup. Made sure everything is per the manual and I get the same error: "no products are connected to navilink"
I finally found this video. https://www.y outube.com/watch?v=zdiKdqUvCPQ. Used the default password, and it works great.
bennecc
@bobryan Can you confirm that you are using the Navilink Lite (not the regular Navilink) with a NPE 240-A (and not the NPE 240-A2) ?
I was interested in the Navilink Lite with my NPE 240-A but when I chatted with Navien they told me that I would need the regular Navilink at more than 2x the cost of the Navilink Lite.
Mark Cam
California
The Navilink Lite can be used with the NPE-A series heaters, in my case a NPE-210A. Navilink is plug and play for the NPE-A2 but there are a couple of parts required to make it work with NPE-A models. This is not a hack it is a factory part conversion. However it will not make an A into a A2, but it will interface the Navilink to the A. You will need to replace the front control panel and the PCB. They are available in a kit or separately:
Navien 30008333D Navilink Front Panel for NPE Series​
Navien 30011690D PCB Control Board KDC330-6M for NPE and NCB Series​
Kit:
Navien 30017405A Navi-Link Kit for NPE Series​
And needed for either installation:
Navien PBCM-AS-002 Navi-Link Lite Wi-Fi System​
The new control panel looks and functions just about like the old one and installing these parts will not change how the NPE functions even without using the Navilink. Installing the PCB and control panel was not difficult, the PCB looks intimidating but comes out relatively easily. There are a bunch of multi pin connectors on the PCB but the corresponding connectors are all unique and they will only fit in the correct plug. Kind of like a puzzle. There are 2 additional multi pin sockets on the new PCB that are not used, I don't know what they are for. There are DIP switches on the PCB, set them exactly how they are set on the old PCB. The switches configure your specific model. The Navilink plugs into the side of the front control panel. You must configure through the front panel setting for the Navilink. You can find the instructions in the complete Navilink installation manual on the Navien web site.
"You can configure the NaviLink connection setting mode from the front panel of Navien NPE and NPN water heaters connected to the NaviLink.
1) On the front panel, press the Power button to turn off the water heater.
2) Enter the R&D information menu by pressing the Up (+) button three times, the Down (-) button three times, and then the Up (+) button four more times.
3) Use the Up (+) or Down (-) buttons to move to “2.PAR” (Parameter information mode), and then press the Info button. Display Description Technical information Parameter information.
4) In the Parameter information time mode, use the Up (+) or Down (-) buttons to select “P.18.” Then, press the Info button to enter the NaviLink connection setting mode.
5) In the NaviLink connection setting mode, use the Up (+) or Down (-) buttons to change the value and press the Info button to set to the desired mode. "On" is for Navilink on."
The Navilink app was very easy to install and pair with the unit and WiFi.
There is not a lot of info about this out there so I hope it helps someone who wants Navilink features on the NPE A series heaters. Just found this on PCB settings:
Bannerman
Ontario, Canada
there are a couple of parts required to make it work with NPE-2 models. This is not a hack it is a factory part conversion. However it will not make an A into a A2, but it will interface the Navilink to the A.
Thank you for your contribution, but perhaps "NPE-2" needs correction.
Silverexpress01
Hello, Thank your for this thread. It's very informative. It brings to light two options....
1. Original Navilink PBCM-AS-001 (for NPE-240A) = $219.95
OR
2. Navilink Lite PBCM-AS-002 = $159.95 (but you will also need the following to make it work with the NPE-240A)
- Navien 30017405A Navi-Link Kit for NPE Series (This kit contains the keyboard panel, and a PCB circuit board) = $279.95
So what advantage would I have going with option #2??? Seems like a lot more costly, and a lot more work. Plus your handling more delicate components. Do you think this is why Navien Tech Support recommends PBCM-AS-001?
Breplum
Licensed plumbing contractor
San Francisco Bay Area
I just pulled a working 10 year old NPE 210A for upgrade swap-out and will be keeping, to part out. If anyone needs parts, LMK.
Fitter30
Peace valley missouri
Any time changing dip switch settings, adding or changing control boards cycling power is mandatory. So the system can recognize changes or else it will go into the weeds.
JRDinIL
MI
Did it have a working NR-20DU with it that you'd sell? (Per my post the other day, I bought a house with probably a 10 year old one with that controller and the controller just blinks alternating green and red, with no apparent way to reset it or do anything else with it, so I can't modify the recirc setup as I need to (and when I tried ordering a new controller online - twice - they've sent me the wrong model, the NR-21DU, which apparently doesn't work with... So I feel like I''m stuck in limbo.
JRDinIL
MI
Kit:
Hi Mark, sorry, it's been a year since your great posts on this, but a quick follow up for you -- I have two NPEs that are connected; if I installed the Conversion kit and Navilink on one of them but left them connected do you think that could still work, or would I actually need to install 2 of everything, which seems excessive...? (It seems like the wall remote that was installed and connected to both no longer works, but I can't seem to find a replacement one anywhere, and the Navilink does seem like a nice option to control on my phone.) Thanks!
Victor23
USA
Kit:
I’ve been using the Navilink Lite with my NPE-240A for a few months now—setup was straightforward, but I found the app interface a bit lacking, especially for organizing maintenance notes and schedules. If you're someone who likes keeping track of things digitally, you might want to check out this comparison between Craft and Notion: https://setapp.com/app-reviews/craft-vs-notion — it helped me choose the right tool for logging maintenance and tracking system performance over time. Both apps can complement your Navien system well if you're into detailed home management.
