Navien NPE-240s-NG Suddenly 93 degrees versus 120
Canadianeh
Ontario
Found this site searching google. My water heater is suddenly only kicking out 93 degrees versus 120 that its set at.
Haven't ever had a problem until today.
I noticed a lot of threads said the check valve could be the issue for Navien heaters.
1) Do you think this is the case? Not sure this model even has a check valve according to the manual?
3) Anything else I can try?
Thanks in advance! It's the NPE-240s-NG model.
Breplum
Licensed plumbing contractor
San Francisco Bay Area
the S series has no check valve.
Error code?
Has to be run through a series of checks to see if it is reading flow accurately.
Ever descaled? that is a question we always ask, but only sometimes relevant.
