Navien CH-180 won't increase supply temp
Discussion in 'Boiler Forum' started by Bathsheba, Jan 31, 2019.
  1. Bathsheba
    Bathsheba New Member
    Dec 14, 2017
    Boston
    Subject says it all: I cannot get the supply temp over 155 degrees no matter what. If I set the supply temp to 160, I get 155. If I plug in the outdoor temperature sensor, regardless of what I set the K curve to I get 155.
    I tried changing the DIP switch to set the return temp instead of supply, but this didn't work: it kept showing the supply icon and only allowed me to set the supply temp as before.
    As long as it's over 20 outside a max of 155 is OK, but below that my apartment drops into the low 60's and I can't deal...it's only a few days a year, but I'd like this to work. Everything I've read says this boiler should be able to supply up to 180 degrees.
    What other factors could be causing this limit? Anything I can fix?
  2. Samat
    Samat Member
    Jan 20, 2017
    You need to change the main Printed Curcuit Board to get it to 180 degrees. Navien supplied me the board for free but I was under warranty at the time. The unit comes standard with a 160 board. I had to do this on my CH210. They also require that you switch to CPVC exhaust piping which is very expensive.
  4. Bathsheba
    Dec 14, 2017
    Boston
    Thanks, I suppose that's probably what it is.
    *sob* I've already had the PCB replaced twice. First time under warranty, supposedly with the 180 degree board, then it failed again.
    Is there any way to tell by looking at this board which kind it is? I see one can buy them online, but I don't want to spend $200 and get another of the wrong one.
  5. Samat
    Samat Member
    Jan 20, 2017
    Can’t help you there
Similar Threads: Navien CH-180
Boiler Forum Navien CH-180 ASME Spare Parts - FREE To a Good Home** Jan 21, 2019
Boiler Forum New home owner!!! Navien ch-180 won't acknowledge thermostat!!! Dec 20, 2017
Boiler Forum Navien CH-180 victory Dec 14, 2017
Boiler Forum Replacement for Navien CH-180 ASME Sep 3, 2017
Boiler Forum Need Help Tuning Navien CH-180 ASME Mod Con Combi Dec 12, 2013
