Robert Brigida
Main T breaks off into front of house and back of house. The back of house goes UP to bedroom, no Tee, then down to basement, no Tee, then return from Bedroom, a Tee, then return from basement, a Tee.
The return from bedroom heat only makes it about a third of the way around the baseboard heater., so that return is cold. The basement heater works fine.
I have had three plumbers try and fail to get it to work.
At one point, the heater down stairs was moved so that I could move a wash/dryer. I am not sure what the configuration was before that, and not sure if that's when the issue started.
On the return from the bedroom, there is some crazy looking configuration with a shut off that I can't figure out what the purpose is. (Image attached).
What does this configuration even do? It's the return from the room above.
