Good Evening all
Thank you for reading my question. I would like to run a low pressure system for processing chlorinated/hard water to a storage tank. The system is a 2.5 ft3 GAC with a Fleck 7000 SXT then running through a 70K 2.5 ft3 WS with a Fleck 7000 SXT. My question is how low a pressure would still yield adequate backwash of the GAC and also create adequate brine draw. Flow is not important this is a 600 gallon reservoir it will be filling which will be used infrequently. From the data on the Fleck it looks like 40 psi will create adequate brine draw in a 3/8 line but I am quite uncertain about the GAC. Any and all thoughts on the matter would be most appreciated.
Kindest regards
Craig
Kindest regards
Craig
