We have a nice Kinetico softener which is as old as the house (about 20 years) and we recently had it rebedded on the advice of the dealer because the water was starting to come out with a slight brown discoloration.
They rebedded it, and the water is better now. But there are a couple of faucets in the house which developed low water pressure afterward (more or less immediately). The other faucets in the house seem to be fine, and in both faucets, the hot water comes out with good force but the cold water is diminished. (?!)
Putting the softener into bypass doesn't help. I called the folks that did the rebed, and they think it's just coincidence - maybe the pump (we're on well water) is going. So we called the well folks and they sent us through some diagnostics and the pump and well seem to be fine (which makes sense, since the pressure at most of the faucets is fine).
I'm wondering if during the rebed, they sent some resin (or scale, or whatever) into the pipes, and the first two faucets we used afterwards are now partially plugged on the cold side. One is an older Moen bath faucet - I can troubleshoot and replace the cartridge, etc fairly easy, but the other is a fancy new electronically controlled motion-sensing kitchen faucet that we put in when we redid the kitchen.
Any advice? Does my suspicion make sense?
