Low water pressure cold
Roberto Martinez
Tucson, Arizona
Hello,
I noticed out of nowhere my cold water in the shower had no pressure, (but there is cold water pressure throughout the house) I was told it might be the cartridge so I replaced it, still no pressure, I removed the danze cartridge and noticed the plate which the cartridge sits in has 3 holes one for hot water one for cold water, I had my son turn the water main on and noticed only the hot water shot out and not the cold, is there an easy fix for that plate or should I just replace it. Thanks in advanced
WorthFlorida
Solutions
Orlando, Florida
Are you sure you have the entire cartridge out? Sometimes the bottom half remains in the valve body. Looking inside the valve body you should see all brass. Is there a separate cold & hot water shut off or stops either attached to or built into the valve body? This is usually a cartridge problem if it has a balancing spool and it sometimes gets jammed closing off either hot or cold water.
Remove the large chrome plate and see if there is a separate piece with a slotted hex head next to the cartridge. If so, that is a balanacing spool and it is stuck. Remove it and tap it on the floor a couple of times than shake it. IF yuu fell something moving inside it, put it back in, otherwise buy a new one.
