I don't know if "hammering" is the best way to describe the sound but this is a very loud thrumming noise, kind of sounds like a loud, noisy machine running, that emanates from where the water line enters my basement and causes the pipes to shake. It happens off and on at all hours of the day but it seems to happen very frequently just after 10 P.M. Sometimes it lasts for seconds or minutes and then stops. At 10 at night it wakes me up and seems to last forever until I get up and turn on the cold water to make it stop. It usually starts up again after a few minutes and I have to go through the whole process again. At the same time I am getting sediment when I run water into the bathtub, and my water pressure went from 60 psi to above the maximum the gauge could read. That was due to sediment clogging the gaskets in my newly replaced pressure reducer. (Replaced by my plumber several weeks ago after the hammering noise had started.) I am the last house at the end of a small dead end street. There are only two houses on one side of the street and a small, 6-8 unit apartment building on the other side. My town water supervisor has not been any help in finding the problem. Any insight you have would be wonderful!
