Home built in 1986, bath tub is on second story. I had a clogged drain and was trying to clear it with a plunger when the snake wasn't solving the problem. The pressure from the plunger caused a leak to appear in the system which is now causing water to leak through the ceiling on the first floor. I have now been able to clear the drain, and water still leaking even without the pressure of a plunger forcing it.
There is no access panel behind the tub, so I 'll either need to cut a panel through cabinet or try to remove the cabinet without destroying it.
My questions:
- What do you think the most likely scenerio is; where is the leak?
- Will I be able to get enough access to make this repair by going through the cabinet on the end of the tub, or will I need to remove the tub (ugh) or go up through the ceiling on the first floor (ugh)?
- Is there any value in removing the tub drain, inspecting and replacing as a first step? I've never done this before but it looks straightforward (famous last words).
Thanks for your help!
Cheers,
Paul
My questions:
Cheers,
Paul
