Replaced main water valve yesterday and took off a ground clamp and of corse it created a pinhole leak.. fixed that and now a pinhole leak has occured in the wall. Its copper that was layed thru a steel sleeve and appears to be packed with hydrolic cement. Full blown beginner diy’r here.. any idea what would be the easiest way to remedy this? Was thinking about taking my rotary hammer and cutting the end on the inside off and outside and just hammering the inside of the pipe as far as i can to clear the cement. Or possibly making another hole and rerouting the line.
