Paul Lavoie
I recently had my laundry and main septic pumped for the 1st time.(6 year old house) I looked in the pumped out laundry tank and saw a short length of pipe with something on one end at the bottom of the tank. I asked the guy pumping what that was as it looked like a discarded piece of pvc. No answer from him. Had to take a phone call so I did not follow up with the guy. Could this have been the downward pipe from the pipe connector at top of tank going to leach field? If so is it vital it be replaced. Per the pic above the water in the tank is pretty clean so no scum or solid layer on top to clog pipe. So is it an issue if the water pulled is from near the top? Also not sure if the pump guy knocked it loose or if it has been like this for a while. Would the PVC float or sink? I did not see floating when the tank was full. Suggestions welcome.
