Kitchen Sink DIY Advice
johnblank79
Illinois
Two main questions as I set out to replace all the current drain parts and install a new garbage disposal.
1) Going from male threaded pipe to PVC at the wall:
As pictured, threaded male pipe coming out of wall. I plan to remove all but the main stub and somehow do a transition from that threaded male pipe to PVC (replacing everything currently there). Do I use a Fernco coupling, a female threaded PVC, or some other fitting?
Bonus question: How difficult will it be to loosen that threaded pipe? Major elbow grease?
2) Overall design of the drains:
I would like to replace what is currently there with what is pictured in the example 2-trap photo (image named GOAL.jpg). Does that seem like a good plan?
Thank you for your advice!
John
