kevinkay
On my 4" Iron stack there is a vent connection. Now the fitting that branches off the vent line is PVC, it has a short section of PVC glued in at each end then a rubber fitting that goes from 4" cast iron to 4" PVC.
I need to move the fitting higher and If there was a fitting that went between 4' cast iron to the expanded ("hub"??) part of the PVC it would would line up perfect.
OR do they make a 4" "street" fitting where at least the top is "street" the bottom is street or coupling and there is a 2" arm?
SORRY - I know my terminology is limited or wrong....... just doing my best.
THANKS!
THANKS!
